Fc starting/idle issues
Started by sheprx7, June 05, 2009, 03:33:59 PM
sheprx7
ok thanks to prof ive found that cutting the fuel by flooring the accelerator makes it start fine when warm. so can the flooding only be caused by a leaky injector?
It\'s got to be one of the most common problems on an EGI, so I\'d say it\'s the most likely.  It could be a bad fuel pressure regulator that\'s letting too much pressure build - but far more likely the injector
