resprayed fd rolling shell
Started by cyman, August 03, 2013, 09:40:30 PM
cyman
as some people have seen ive run out of time and space to get stuck into the fd and start getting it back together. I bought it as a runner needing finishing and was planning on putting it back on the road with an aim at lots of trackday fun.
I basicly have everything to put this back on the road minus an exhaust and ecu.
I will sell this in any spec needed including many of the bits I have gained obviously price dependant but of course buying more of it together means you get more parts cheaper than I will sell them for on there own  :D:D
the starting price for the car with all bodywork, all interior with later plastics, all suspension arms the back ones are polybushed with pretty new pillowbushes, all brakes and vented bonnet, flared front arches on orig wings. this is all for £750 in this guise you will need some shocks and wheels for it to be rolling.
as above with the rz diff still fitted, meister r coilovers, feed replica side steps, 18 " rota d1 alloys 8.5 front 9.5 rear matt black with federal rsr 265 rear and 225 falken 452,s on the front all tyres have around 3/4 tread left £1500
other bits I have which can be included if needed as follows
Custom v mount with rad.intercooler.pipework.bov and flexis and slim fans
Racing beat antrollbars
Full brand new arb rose joint links for front and back
Brand new rose joint track rod ends
Os giken twin plate clutch that is like new
Os giken push pull convertor with the rod which has just been made for me by danny
Rebuilt gearbox
B and m short shifter
Profec b 2 complete
3bar map sensor and wiring harness to fit into standard loom
Twin spark with loom
Carbon look rear battery box with wiring and a new calcium battery
929 master cylinder
gearbox brace with rubber bushes re wing type
Greddy tyle c wastegate
Greddy stainless manifold
My hybrid t04s that rocks
Jaydee built engine with streetport. The compression was high 6.s when checked but there is a possibility of water seals on way. I was going to fit it and see how it went and then k seal it if needed or rx motors reckon a refresh can be done with new tips and seals for around a grand. Comes with uim.throttle body.coils and primary injectors
Brand new riat with wiring
Secondary injector rail
Brand new aeromotive fuel pump
Aeromotive fpr
Cheap copy ally rad works perfectly
frp undertray
diff mount with uprated poly bushes fitted
2 different types of solid engine mounts both on arms one set is nylon other set is an aluminium and rubber mix
standard brand new clutch
there are plenty of other standard bits that can go with the shell no matter what they include full set of hubs the rears have new bearings,driveshafts,standard headlights and motor set, various plastics and other bits left over from the other fd.
any of the above parts will only be for sale once the shell has gone and the person buying it has chosen what they want.
here are some pics of the car and I have pics of most of the bits listed if needed
Jot17
Hi, if ur breaking you see the passenger side vent next to the front wheel, I need that as mines missing but depending on what colour code is your vent, so if you could please let me know.. Thank you
Dante
In case You are selling Mister R, let me know
Oliver
If you could PM me your phone number, I would like to speak with you.
cyman
