Number Plate Question
Started by SavageUK, May 04, 2007, 07:03:29 PM
SavageUK
Hello all,
As im under orders to move my number plate, i have aquired a number plate "sticker" of sorts. It is however the normal numberplate stuff, which is then usually attached to the hard plastic backing with a heat gun of some sort.
my problem is now attaching it to my car, with it not being a true sticker there is no sticky backing. What can i use to attach it? wouldnt want it damaging the car obviously if it had to come off for whatever reason ( if it takes much effort to get off but leaves the car ok, im good with that )
i leave my problem with you knowledgable folks :guinness
cheers,
pete sparrow
Quote from: SavageUKHello all,
cheers,
Hi
 Why don\'t you get a proper stick on one for under £20 off Jono at D-Sign Studio??? Personally i think you\'ll be happier with the results!
 If not then use double sided tape,motor factors sell it for sticking number plates onto bodywork.
Jono FD3
Hai-ho, if you\'re interested let me know!!
Cheers for the free plug pete ;)
How did the fitment of the graphics go?? Forgot to say I put some extra vinyl in if you wanted to cut a few more tairs!!!
Jono
pete sparrow
Quote from: Jono FD3Hai-ho, if you\'re interested let me know!!
Jono
Run out of time and light mate.Going to tackle it when i\'m feeling a little braver!!
SavageUK
ah ok, double sided tape it is then. gonna see how it goes/looks, if its pants ill order one ;)
Jono FD3
Think you might find if it\'s not secured all over then the material will tair as it is very brittle!!
Jono
