Oil additive ???
Started by interloper393, July 12, 2005, 02:01:10 PM
interloper393
Hey guys just have a wee question for u`s :)
In ma last 4 cars iv added a additive called X-lube into the oil, its a kinda super lubricant, works great, just wondering if its ok to add to ma rx7? and also if any of you have you`d it on yer rex  :wave
On the last 2 cars iv had its reduced the engine temperature quite a bit so was hoping it`ll do the same for the rotary...
 :3gears-rh
Try searching on this, as its come up a couple of times before.
I wouldnt add anything though.
interloper393
There seems to be a bit of a 50:50 view on it lol, a few say it will lower the engine temp but may damage the rotor tips :P
And what would you rather have, lower engine temps and the poss. of a shorter engine life, or add water wetter and normal oil. Questions qestions, but what is a man to do????
interloper393
g11ary
if your is that crap you need adittives, buy a better one. Not worth the risk of your engine.
interloper393
Quote from: g11aryif your is that crap you need adittives, buy a better one. Not worth the risk of your engine.
I wasnt going to add because its crap, i was going to add to protect it better :P
but **** it!! i aint adding **** now!! :)
g11ary
What I was trying to say is some oils (ie morrissons) not that you are using that, cost £2.75 a 5 ltr drum, so the money would be better spent on upgrading the oil.
Have another meeting with someone today who I will ask about X lube.
Martiny
Quote from: g11aryHave another meeting with someone today who I will ask about X lube.
Gash, THAT sounds really dodgy !!! :chat
g11ary
Ohh eeerrrr
Does a bit, were\'s bish just when you dont need him :-)
oilman
Dont use addatives, there is no substitue for using quality oil instead.
Most magic additives can do more harm then good.
Guy.
oilmans website://www.opieoils.co.uk
e-mail:sales@opieoils.co.uk
tel:01209 215164
g11ary
Seen my man today, he said same dont use additives, not much cop in a crap oil, so spend more, or in a good oil could change the balance and end up being worse, upsetting the blends.
interloper393
Whats the best oil to use ? heard good things about that purple oil :)
oilman
It depends.
If you want a proper synthetic then I would highly recommend something from Silkolene or Motul as they contain esters.
If you want to stick with mineral then a petroleum based semi-synthetic is better than a straight mineral oil as it\'s more thermally stable.
Viscosity wise 5w-30, 5w-40 or 10w-30, 10w-40.
Simon
tel:01209 215164
interloper393
Cheers guys, after having the rebuilt i want to make sure shes well protected :)
