Rx8 clutch and flywheel the same as an fd?
Started by Grant Monkhouse, May 28, 2016, 03:59:56 PM
boosted
Lol i meant rotary car parts.
Sent from my SM-N910F using Tapatalk
Grant Monkhouse
Quote from: boosted on May 28, 2016, 08:07:14 PM
If you look closely you can see my spare engine on the floor in front of the digger
Sent from my iPhone using Tapatalk
Grant Monkhouse
There's also a water pump in the picture too. Found one of my EWPs in there today also. Other one is in the shed
boosted
Yeppp zoomed in.
Grant Monkhouse
Had that engine a while now and it's still as good as when I got it, turns over by hand so easily and has great chugs and puffs as it intakes and exhausts. Rather have a pile of £20 noted though than the engine lol
Smiffers
Quote from: Grant Monkhouse on May 28, 2016, 07:31:27 PM
This is the clutch I have
http://www.mazdarotaryparts.com/brx-7-fd-hks-twin-plate--flywheel-clutchb-737-p.asp
Probably be able too swap it if necessary. Just thinking that if I need to put a new clutch in my car I will put something better in it if I can. Plus the flywheel probably be a lot lighter too
That is a pull type clutch so can't go into the 8, you will need to measure the pitch of those stand-offs to see if you can make a push type fit on the flywheel...  Does not look as modular as some so it might not be possible.
Westfield SEiW - 13B-MSP BW 7670 Turbo
www.facebook.com/rivetracinguk
