Think I\'ve got a boost leak?
Started by B.Martin, August 11, 2011, 07:43:35 PM
McPie
Right
it start  from first turn, but it don\'t keep RPM\'s
If I use throtle for keep rpm\'s it feels like it a little struglink to burn up everything, thinkg of backfiring, but no fire on low rpm...
it doesn\'t mater cold or warm engine.
I have check for air/vacum leak, all fine
CO2 sensor is fine as well, then I decided to unploag air flow sensor and started car again. Hmmm it was working on 1500RPM a little bit jumping, but working. After I pluged it back the car again do not keep any rpm\'s
Any Idea\'s?
Doc at your service...
if your rotor doesn\'t work, try to seek for problems in washing maschine centrifuge...
929 + RX7 = RX4 powered 13B TURBOII
