egi gearbox bellhousing on tii gearbox?
Started by monterx7, January 26, 2011, 01:01:05 AM
monterx7
does anyone know if its possible?  will a egi bellhousing bolt up to a tii gearbox?  reason being i have bought a mean twin plate clutch/flywheel setup and found out the flywheel is for a non-turbo.  the company does not make a flywheel for turbo models, not sure why, and just tryn to see what my options are
88 gxlt US spec
86 egi UK spec
Brett
Are you sure the clutch is correct for a T2 then? IIRC the splints are different on the shaft...
Brap Brap Brap Brap
Quote from: Brett;738985Are you sure the clutch is correct for a T2 then? IIRC the splints are different on the shaft...
What he said - different number of splines between EGI and T2 - T2 and FD are same number of splines.
I also think the T2 bell housing has different bolt pattern to EGI.
monterx7
Quote from: Prof;738986What he said - different number of splines between EGI and T2 - T2 and FD are same number of splines.
didnt think about that part.  the flywheel is 116 tooth.  what i dont get is, why would you make a flywheel that you could bolt on a twin and even a triple plate clutch for a non turbo:xconfused
can anyone confirm they have different bolt pattern at the bellhousing?  not trying to force this to work, but just making sure i have explored every angle before i send it back off and try to get my money back for it
thanks for the info
88 gxlt US spec
86 egi UK spec
monterx7
i believe on a non turbo the clutch spline is 22 tooth...and turbo is 23.  i bought 2x 23 tooth clutch plates just didnt realize the flywheel was for non turbo until i bolted it on the motor and saw the difference
88 gxlt US spec
86 egi UK spec
pdtaylor18
Go buy a FD flywheel, they are lighter and fix straight onto a FC lump.
Email: pdtaylor18@hotmail.com
Pete[SIGPIC][/SIGPIC]
monterx7
the clutch setup i have is a 7.25", here is a sample pic of what the quarter master twin plate 7.25" clutch setup looks like.....
88 gxlt US spec
86 egi UK spec
