Rust here rust there rust every frickin where
Started by 1990_fc3s_t2, February 20, 2010, 03:47:49 PM
TiddlesRX7
Good work bud. Fingers crossed you get her MOT\'d in time for Rotorstock.
L18M
awesome work :)
camers: maybe its the setting? make sure its not on macro.
else turn off flash if poss?
i think the biggest prob might be as teh car is white and the main focus on the camera is in the middle it neglects the outside contrast so the centre is the main focus, plus white car, reflects more light so whilst car is bright the rest is dark.
hth :)
1990_fc3s_t2
Cheers, im still buzzing it started so easily and the new clutch seems good as there was no judder setting off in first although i only went about 4ft with no seats or doors!!
think i sorted the camera, i had it set on auto and it seems to work better on manual, I should read the instructions to see what that actually means!!
captainbizzaro
Quote from: 1990_fc3s_t2;706963I should read the instructions to see what that actually means!!
That ain\'t the mans way, you gotta break it first- then read the instructions.:D:D
