S5 waste gate porting
Started by dthebuk, April 27, 2010, 03:39:43 PM
dthebuk
Just a few quick questions.
going to be running a 2.5 inch downpipe connected a free flowing 3 inch system and ive decided to port the waste gate.
anyhu, just wanted to know how big to go and what the stock size of the waste gate is. Also if the waste gate flap will need replacing for a bigger one.
by this time the car should be running a front mount too.
Oh, its a stock turbo
cheers
:burnout
TiddlesRX7
I did mine recently. I just went easy with it as I didn\'t want to take too much out. I could have taken quite alot more out TBH.
Guide below
http://www.fc3spro.com/TECH/HOWTO/KWG/kwg.html
dthebuk
thank you very much!!
you didnt measure your\'s before you put it back together did you?
:burnout
TiddlesRX7
I can get the measurements of a stock one if you like. I have one in bits at work. But no, I didn\'t measure the one I ported. You kinda can see when you get into it how much you can open the holes out. Then its just a case of cutting the back of the hole out to suit. Just don\'t go too daft with it. Leave the holes a mm or 2 smaller then the wastegate flap.
dthebuk
ah sweet, i was thinking something along those lines.
Cheers for the help. muchos apriciated
:burnout
TiddlesRX7
No worries. If you FUBAR it give me a call I have 2 spare housings!
