Mad jumping rev counter!
Started by rx-dave, September 24, 2008, 10:10:51 PM
rx-dave
Just had an RX7 in with a mad rev counter! It\'ll vary wildly from 4kRPM on tickover then goes to over 10k RPM when revd gently........any ideas??
Thanks in advance,
Dave.
Eddie
hi Dave its common problem with rx7 rev counters, do a quick search loads have had a problem.
its to do with dry joints on the board.
I replaced mine, think i have 1 spare will have to check £35 posted if you want it.
regards
shaunwil
Its usually the capacitors on the back of the gauge have grown and degraded. You can re-solder new ones in if your that way inclined.
Shaun
rx-dave
Quote from: Eddie;540127hi Dave its common problem with rx7 rev counters, do a quick search loads have had a problem.
regards
Many thanks for the help guys, Eddie i\'ll buy that from you if you still have it.
Dave. (07810 098199)
karl_tate
mine was just a loose connection :D
____________________
XBOX GAMERS TAG --- tatey1985
Eddie
Will hunt it down for you need to get into my garage so can do that tomorrow mate.
will give you a call tomoz.
but as Karl said try wiggleing the connections on the back first you never know.
cheers
Eddie
So sorry forgot all about this, will pull it out Monday, let me know if you still want?
rx-dave
Hi Eddie, no worries matey and yes i\'ll still have it  :chat
Dave.
