Aerial Removal
Started by johnf, June 10, 2007, 09:45:49 AM
johnf
I need to sort out my FD aerial, either by mending it or a replacement.
Problem is it\'s currently stuck up.
So having undone the mounting bolt there isn\'t enough clearance to get it out.
So, how\'s it done.
john
interloper393
theres a metal cover at the top that i had to remove to get mine off...
probedb
Yup, top of the outside bit unscrews and there\'s a bolt inside....takes a bit of fiddling but it will come out :)
Mobilemick
Quoteeither by mending it or a replacement.
Snap it off and Replace.  Job Done  :)
johnf
That\'s the easy way but perhaps not the most cost effective.
The aerial makes ratchet noises when powering on/off so I guess something is slipping.
This sound familier to anyone and is it fixable?
John
interloper393
i just took the whole lot out of mine and flushed it off, so not much help.. soz bud.
Mobilemick
It`ll either be rusty inside, or the cogs are made of plastic and be broken, you could buy a kit to fix it,  but its most likely replacement :)
