BHP Expectations
Started by ReX 813, December 02, 2006, 11:18:41 PM
ReX 813
hi,
just wondering what sort of power i can expect from my car,
its a type R2 with a street port, power f.c, induction kit, and exhaust system with de-cat which has just been fitted, its still on stock twins+injectors,
im getting it re-mapped soon but was wondering what i could push it to without causing to many problems??
cheers Jay
Warthog
Where are you getting the mapping done, is the first question.:wiggle
Project Evil seven.:evillaugh
nikp
And: You\'re running a street ported engine without a custom map!? Dangerous.
Bramble
Also where was the street port done? Is it a UK port or a fictitious Japanese port?
I would think it would make 330-350 flywheel as a wild guess.
ReX 813
Ill be taking it to RE-WORX, the mapping was done there bout a year a go by the previous owner, it came out at 276ATW with the cat on, but i have been told the map was set to be economical, and i could get more from the car?
the port was done in the u.k.
John Yorke
to get the best out of it you need to address the fueling, bigger - pump, FPR and a pair of 1600 injectors. As it stands you could see around 280 / 290 atw and you will then run out of injector duty. With the fuel mods and a free flowing exhaust you should be able to push it over the 300mark.
peterwolds
got 305 atw on mine with additional injectors ,power fc and a walbro 255 L pump stock twins with wastegate modified
:Typing Pete
ReX 813
Cheers john, looks like ill have to spend my pennies on some injectors and pump in the new year,
good figure that pete, id be happy to get that :Thumbs-up
