HELP: Any tips for Removing Pilot Bearing from the Eccentric shaft
Started by antnicuk, November 05, 2006, 04:44:04 PM
RotorHeid
WoW!, quick reply from everyone, well said!!,
just finish my haggis and oat meal.
antnicuk
thanks clive  :) ,    a circular one will not cut along it,  just wondered what shape tool would
kev-yorks
Quote from: oldoneThere you go overdoing it again......:spank 6" is more than adequote(sp)..:wiggle
No when i go overkill Era i get the gas axe out!
Kevin
Regards Kevin
RotorHeid
If not move! , use a bolt(grip by vice) to screw in and tug the bush  out!
oldone
Quote from: ian duncanWoW!, quick reply from everyone, well said!!,
You Scottish are differant(sp).......haggis and oat meal ?,sounds like horse food....:wiggle
RotorHeid
Wooo! ,bet ootya!  me behind yer back at auld schoo met:eek
oldone
Quote from: ian duncanWooo! ,bet ootya!  me behind yer back at auld schoo met:eek
As long as you bring some haggis for me to sample bud !!!!!!!!!:Typing
RotorHeid
Timrxmotors
Quote from: oldoneSteel porting bits bud....:evillaugh :cool  destroy it and yank it out......eccentric shaft material is very hard.....:2eek  so dont be bothered about a mark or two as the outer shell of new bearing covers it !!!!!!!!:D :Typing
The shaft is far from hard,you can cut it with a hacksaw.The bearing case is hard,and the hole it goes into must stay perfectly unmarked,any burrs will push and deform the bearing.If you chisel it out you will be for ever trying to make the hole round again,I mean for ever! You need the proper puller,even if all the needles have gone,the puller will remove what\'s left,easily.
oldone
Quote from: Timrxmotors
Oh! you are such a perfect princess....:wiggle :evillaugh :guinness :Hammer :cool :2Rolleyes
antnicuk
only problem is i have no lip left at the outside end of the casing?, does the puller grip the outer lip or the inner lip?, i think i still have some lip on the inner edge
anyone have a puller i could borrow?
Its easy, Not to sound Rough but i Distroyed mine with a Screw driver and a Hammer.
I tryed all sorts at first, things like getting a few Washers that just fit inside the bearing then put a Bolt through them and a Slide hammer on the end, that worked ok to a point then the Washers started to go out of Shape and it just slipped off, So i lost My Rag and hit it with a Hammer :)
