Engine removal (after compression test)
Started by Mr_7, July 09, 2006, 12:08:29 PM
davehg
going back a few posts you WILL need to take off the downpipe as you may end up getting it jammed on the bulkhead. its not much work to remove it in situ
Putting it back maybe but taking off??? its all about getting the gear box in the right place, Having the engine mounts off and moving the engine as far forward as poss before lifting it too much.
Taking the down pipe off before removing the engine is dramaticly harder to do than taking your time with it on.
stuart wizy
I took the mounts of and jacked the engine up to max height then undo downpipe bolts. Make sure u have definatly undone all bolts from clutch to flywheel through little inspection cover at the bottom of the bellhousing, then give it a good wiggle pulling and she will come out.
nikp
Quotegoing back a few posts you WILL need to take off the downpipe as you may end up getting it jammed on the bulkhead. its not much work to remove it in situ
I concur with Dave on this....mainly because we tried taking the engine out of mine with the downpipe on, and it did become jammed. It was a lot easier to remove the downpipe before removing the engine.
Mr_7
thanx guys unfortuantly its to wet here to finish taking it out tommorrow so will have another go tommorrow cheers again
Mr_7
hey guys thanx for the help got home from work today and started straight on it once i took the weight off the gearbox and removed the manifold off it slid out like a well lubed ho.
thats part one done now im 2 days behind schedule this weekend i will strip it down to the housings and rotors so looking forward to that also picked up a huge solid metal workstation to build it on soo all good here
thanx again all
Mr_7
oh also bought soome nice 3" dished 18\'s for it today and a full carbon spoil so looking goodnh
richard cash
Are all these things mentioned the same principle in any car? My mate who is helping me take mine out has done loads of engine removals on european cars and fords, but nothing as "exotic" as a high powered jap car.
