odd problems
Started by msc125, April 05, 2006, 09:40:32 PM
msc125
been a while since i\'ve been on, so hello again!
i\'ve been neglecting the rex as of late, and she ain\'t happy about it! i\'d left her for about 3-4 weeks without starting- just never got a chance. anyway, when i went to start her the battery is, unsurprisingly, dead. i changed the battery and have now got the following problems:
the apexi display has gone a bit funny, see pic. i think it\'s showing the max value for each reading, it never did that before
she drives fine in 1st gear, but as soon as i change up to 2nd, there is low power, even with pedal to the floor. sometimes, boost is loooow and it hardly goes anywhere. when i let off the throttle there is a quite an embarrassing \'cooo\' sound! kinda like a depressed pigeon!!  :xconfused !!
other times boost is almost 10psi, and it revs up quite quickly, but the power doesn\'t match the revs, maybe clutch slipping?
on the (very) odd occasion i get full boost in 2nd/ 3rd gear or above, there is a noticeable stuttering as revs increase. could this be misfiring?
finally, when i turn the engine off, the boost gauge settles at odd values in vacuum.
sooooo, there are a few problems, but they are all intermittent. i searched a little bit on the problems, and will check the fault codes as per this thread as soon as i get a chance:
http://www.mazdarotaryclub.com/forums/showthread.php?t=23608
cheers kev-yorks!
mods:
apexi power fc, base map
apexi twin induction kit
racing beat twin exhaust, de-cat
can anyone shed any light on these probs?
can i reset the ecu to the base map again?
(just realised, i can\'t post attachments- must renew membership)
thanks
kev-yorks
The blink code list is for the stock ECU i don\'t run a apexi myself so not 100% sure but i think it has a error check function for checking faults one of the many FD guys running the apexi will no doubt post and let you know for sure.
Kevin
Regards Kevin
M@r]{
The Maximum Readings whilst in Monitor mode is selected by pressing the Up arrow, to go back select the down arrow - not sure if that s what you mean though   :2Rolleyes
nikp
Are you running an electronic boost gauge, or mechanical boost gauge? If it mechancial, then i guess there\'s a problem with the boost gauge. If it\'s electronic, then there\'s either a problem with the boost gauge itself, or with the MAP sensor - and, incidentally, it\'s common for faults to occur with the map sensor, and can give problems similar to your own.
msc125
d\'oh! i pressed the down arrow on the apexi, and it\'s back to normal...  cheers mark
i have a mechanical boost gauge, so i\'ll check the piping on that
could it be misfiring? or is it more likely a ground fault as per the link in my first post?
......but the sound is bizarre!
