FC offsets???
Started by tr1cky, March 04, 2006, 07:14:55 PM
tr1cky
Hi,
Can anyone tell me what the offset is on a standard FC wheel?? along with the wheel width?
Seems to be loads of info on FD stuff, but very little on FC\'s :confused:
Would like to know so I can figure out what offset I need for some wider wheels :King
Cheers rich
The FC is dead, long live the FD
grinder
hows this :
RX7 - 89 to 92
PCD  : 5x114
Offset  : 35 to 45
Bore : 59.6
Not to sure on the bore figure - but the rest looks OK :D
The tightest man on earth
:Giggle
tr1cky
thats a good starting point Stu...
If someone, maybe you Stu, could let me know what width rim and offset they are running(so I know it works!)??
That would be great!
grinder
i cant think what the FC runs i think its 6JJ wide
you have to be careful on the FC as im not sure what size you can run on the fronts due to the front shocks
now i think that the FD has 7JJ rims - and they are tooo wide to fit on the fronts without spacers .. like i said - im not 100% sure matey
Stu
:Giggle
jetpilot
I am running 8.5 fronts, 9.5 rears, i think the offset\'s are around 42 - 45, using a 5 mm spacer on the front but rears are ok.
tr1cky
OK
Seen some wheels I like, but think clearence of the arches is going to be a problem!?
8.5front with ET+30 offset
9.5rear with ET+30 offset
From my understanding the fronts would stick out too far by around 5-7mm and rears by about 10mm, am I right??
88GT-R
8.5 with a +30 will be neigh on perfect for the front.  9.5 with a +34 is just inside the rear arches, and with about 10-15mm clearance to the shock.
John
tr1cky
So John,
Are these the offsets you run?? Only alot seems to be said and it is very difficult to find a setup which is known to work!
Wanna make sure I get it right 1st time round and not have to use spacers
Cheers Rich
Quote from: 88GT-R8.5 with a +30 will be neigh on perfect for the front.  9.5 with a +34 is just inside the rear arches, and with about 10-15mm clearance to the shock.
John
88GT-R
I am running 9.5 +34mm on the back, and have the same for the front, which are not fitting at the moment. I have not tried the 8.5 +30mm, but am confident that it should be good. Have you had a look at //www.fc3spro.com website or asked on //www.rx7club.com
John
tr1cky
Cool! Thanks mate :WaveBye
Yeah looked at both sites, seems to be alot of conflicting info from different people though. But some good info too.
Pretty confident the fronts will work now though. Got a feeling the rears will require the arches rolling or maybe even pulling out abit...Any ideas??
88GT-R
They will only need a touch, as my tyre sits about 4mm in from the lip.
John
tr1cky
Quote from: 88GT-RThey will only need a touch, as my tyre sits about 4mm in from the lip.
John
Excellent, cheers for your help mate, made up my mind now! Can hear the wallet screaming for help already :evillaugh
