which rx7??
Started by ryanshepherd, November 12, 2011, 06:02:31 PM
ryanshepherd
i\'m not fussed about which model at all really, just that coming from mr2 turbos, you see some really cheap revision 1\'s, they have no limited slip diff and a paper head gasket, smaller brakes and different suspension, and are harder to get power from, whereas the revision 3 has bigger injectors, better flowing turbo, steel head gasket etc... didn\'t wanna rush into buying the rx7 equivalent of the revision 1 model :) only to find out i want later spec brakes/springs etc :) i\'d rather buy the best spec i could :)
Squallai
If you say the best spec, i would say spirit R~~
