what sort of tyres to run on my new rims
Started by almeida1234, July 28, 2011, 04:42:22 PM
almeida1234
hey guys just wanted to clarify what sort of tyres I sould run on my new rims
they are 18\'\' alloys
they are 8x18 with offset of 34 up front
9x18 with 42 offset at rear also what sort of tyre pressure to run?:driving
can I run 225/40/18 and 255/40/18 at rear without any rubbing
and it is for 2000 rx-7 type rs
thanks
yehreally
Depends on budget, use, questionable longevity open to question and pics as we are interested :guinness
wolfie1
i run michelin pilot sport on my fd and have just got a set of bridgestone s02 for when the back ones need changed, avon make a very good grippy cheap tyre , the zv5
dthebuk
Those offsets are pretty weak so you should be fine IMO.
I run 205 width Avon zz3\'s on the front of my fd and the amount of grip they give always surprises me!
:burnout
Indian
I run 245/40/18 and 265/35/18 on my 2000RS too. I think my offset is the same or a tad more aggressive than yours. I ran 275/40/17 drag radial on the track and never rubbed with countless launches, so I think  you should be more than fine with 18\'s.
The most important thing is to make sure that your tire heights are the same or close as possible.
