FD3 oily smoke on idle....
Started by suba, June 02, 2009, 09:34:22 AM
suba
After a run (not on startup) my FD3 has started smoking a bit on idle (blue smoke)  When the engine is revved in neutral the smoke dissapears.
Before I decide this is the turbos oil seals is there any other likely cause?:)
Single Turbo time!
suba
One thing that I have noticed is that after a full service I could not hear the DV\'s (standard re-circ) dumping when lifting off.  The car runs an ARC induction box, and prior to the service I could hear the DV\'s well enough?.... Maybe there is a restriction somewhere?
Single Turbo time!
Bobbit
smoke on idle is usually the turbo seals bud as you\'ve guessed. Are the standard CRV and ABV plumber into the arc induction? if so then you shouldn\'t be able to hear them anyways.
:Laugh LOL
suba
Single Turbo time!
Bobbit
charge relief valve and air blow-off valve, the 2 bov that look identical to each other.
:Laugh LOL
suba
thanks - yep, they are both plumbed in.
Single Turbo time!
Bobbit
You\'ll not hear them then bud so that fine. If you miss the sound then simply remove the pipe leading back to the induction kit and blank off the empty connector on the induction kit. Much cheaper than buying aftermarket and TBH sounds identical.
:Laugh LOL
suba
Does that create any issues with idle or reading unmetered air?  sorry if that is a daft question - still getting to grips with the 13B!
Single Turbo time!
Bobbit
it didn\'t for me bud. As long as you blank off the remaining holes you\'ll be fine. As far as i know it helps with engine temps as the air released by the standards BOV\'s is hot and is released back into the air intake, so stopping this happening can only reduce intake temps.
:Laugh LOL
SiH
No p[robs with unmetered air :) It\'s a MAP system not MAF, so you don\'t get that iddue :) So just bung up the holes on the airbox so you don\'t draw in any any unfiltered air.
suba
Sweet - No more MAF sensor tuning issues for me then!
Single Turbo time!
