quick engine removal question
Started by RXphil, April 27, 2009, 10:01:59 AM
RXphil
I have an fd3s, can i leave the gearbox in place when removing the engine, or does it have to be removed as the manual says?
Thanks in advance
ro284
QuoteI have an fd3s, can i leave the gearbox in place when removing the engine,
Yes, i did mine, for its rebuild, but mine is a manual, i dont know about Auto, if its an Auto box its any different,
RXphil
mines a manual too mate, so did you just unclip the clutch a pull the engine out then?
leon
Unclip the clutch, undo everything else thats holding it in place and pull and swear! you can brace the gearbox with wood or somthing. thats what i did!:yes
I woof in your general direction.
RXphil
Nice one, ill crack on then. cheers fellas
karl_tate
jack the gearbox up as high as it will go to give clearance.
i also found that the engine mounts fouled the subframe so i just slackened the 3 bolts on each side to give more room.
____________________
XBOX GAMERS TAG --- tatey1985
slingo
i slackened of the subframe to give me clearance,went very smoothly but any way will work
RXphil
Great job, engine out now. Only had to jack gearbox up and remove drivers side engine mount.
Thanks again boys
:cheers
leon
