Broken water pump??
Started by L18M, November 11, 2008, 02:57:16 PM
L18M
since doing a coolant change my rad light always come on soon after the loud pedal is de-pressed.
when the light is on and the loud pedal is pressed then the light goes off soon after.
the stock temp guage is kinda useless and the aftermarket one i got in there is playing up / not reading a temp (might be due to broken wire but works intermittantly)
would this be signs of a broken water pump?
once the car is started i pressed the loud pedal and can hear water swooshing around in the engin bay.
any help would be most greatful =)
colin5524
L18M
lol..
yeah.. have done n they all moving =)
dont look like any are missing apart from the ones that go with the air pump. (ps air pump is removed)
grinder
with the air pump removed - you NEED to run a dual alternator pulley or the belt can/will slip on the water pump - and if its doing that - then it aint pumping water
The tightest man on earth
:Giggle
L18M
Quote from: grinder;553426with the air pump removed - you NEED to run a dual alternator pulley or the belt can/will slip on the water pump - and if its doing that - then it aint pumping water
hm.. was ok in summer time. i guess i best get the pulley fitted finally lol
Brett
If you are in any doubt then get a new pump - not worth the potential damage.  They are around £100 IIRC - Clive got me one in a hurry a few years back - so give MRP a ring :)
Brap Brap Brap Brap
