NO power until turbo kicks in =(
Started by L18M, July 26, 2008, 11:05:48 PM
L18M
exactly as the title sais.
when pulling off theres no power and a 1.3 micra can beat me at the start line until i hit around 3k revs n the turbo kicks in then i fly.
anyone for ideas?
last tested compression in march n it gave even results about 6.5 all round.
i have no ideas about these things.
thanks in advance
TiddlesRX7
Are you sure your in the right gear? if you get court out at low rpm\'s in too higher gear you\'ll bog down. Dropping it a couple of cogs usually helps :)
L18M
lol, even when i acc from 1st gear theres no power.
i raced a civic type r the other day n he ****ed on me until the boost kicked in.
once it gets goin i can poo all over a celica GT4
im sure 1st gear is left then up
1  3  5
:_ :_ :
2  4  R
prince_of_tokyo
is yours a twin mate? if so have a look at your boost guage to see if your primary turbo is spooling
WAS;
1994 FD3 Type R-II
all TRUST/GREDDY prepared
T78 blower
big street port
500bhp
one happy driver... :yes
NOW;
Porsche 996 C4 CAB
TiddlesRX7
I dunno then. How does it run at low rpm\'s? maybe you\'ve got a week spark for some reason and it clears itself as it rises in rpm. Think I would investigate that route first. New plugs maybe some leads. You can check the resistance of the plug leads first and that will give you an indication if one of the has broken down slightly.
Low to mid power loss could be down to Fuel pump/fuel pump resistor, overfuelling at lower rpm\'s, timing could be out, plugs, alternator / electrics / ecu / a sensor out somewhere.
Probably worth checking for ECU fault codes see if there is anything showing up,
L18M
thanks for the reply. i 4t maybe timing cos sometimes when i change down the exhaust pops but then that could bt the air
are the lead and trailing leads the same?
if so i may try swapping the leads for a start.
i kno the coil gives gd sparks as this was tested in feb aft i brought the car n took it to haywards for some trouble shooting.
anyone kno where i can get the timing checked out around london / middlesex area?
you prob all kno i got about 0.01% mechanical knoledge lol
I would change the plugs, change the air filter and change the oil and see what happens, also check around for any loose wires or hoses, perhaps check the back of the engine where the intercooler attaches to the engine?
L18M
Quote from: Prof;519788Low to mid power loss could be down to Fuel pump/fuel pump resistor, overfuelling at lower rpm\'s, timing could be out, plugs, alternator / electrics / ecu / a sensor out somewhere.
how do you check for ecu fault codes?
