Greddy Profec B Spec II solenoid positioning
Started by nikp, October 30, 2006, 11:18:34 AM
nikp
I have received my boost controller (Greddy Profect B Spec II). I need to install the solenoid somewhere into the engine bay, but don\'t know of a good place to put it.
Has anyone got any pictures of theirs installed, preferably single turbo applications. I don\'t know where to put mine! :xconfused
Jake
Quote from: nikpI have received my boost controller (Greddy Profect B Spec II). I need to install the solenoid somewhere into the engine bay, but don\'t know of a good place to put it.
It\'s not a single but I placed mine under the air filters as there are screw holes going spare and it\'s close-ish to the wastegate.  If I didn\'t have an oil catch tank I would have placed it in the top left of the engine bay but the catch tank took up that spot.
McCARTHY
mines on the bulk head behind the driver side front wheel arch
nikp
Quote from: McCARTHYmines on the bulk head behind the driver side front wheel arch
Any pictures?
McCARTHY
yes ... yes i do ... don\'t know if this is the same with the greddy one but HKS say not to mount the solinoid upside down as it can effect boost control... i had to turn mine around because it was mounted upside down....
rx7veilside
mount it away from heat as much as poss and yes with middle vent facing downwards to stop water and dirt ingress...mine was mounted before i got the car by a tuner right next to the turbo and with vent facing upwards:(
McCARTHY
nikp
Bugger! The corner that McCarthy has his would be good....if my alarm unit wasn\'t there!
rx7veilside
on the abs side of car u will prob find a spot..i was thinking of moving my catch can anyway
antrosser
can anyone include pics of how to fit the Greddy Profec Spec II to the rex? Greatly appreciated if you could :-) do i need to drill any holes into the turbo to take direct readings?
LRP
Quote from: nikpBugger! The corner that McCarthy has his would be good....if my alarm unit wasn\'t there!
snap i managed to squeeze mine onto the earth strap mount that comes from the plenium but mines a type -s not sure if different?
complete wankel :god
antrosser
Yea, thats where mine is mounted too :-) just make sure you surround it with the rubber washers to insulate it from the earth coming from the engine!! lol
nikp
Quote from: antrosserjust make sure you surround it with the rubber washers to insulate it from the earth coming from the engine!! lol
what are the implications of this if there is contact with bodywork? As I just checked mine, and there was contact. So I have now corrected this, but was curious to know what issues it may have caused?
chrisJDM
heres a couple pics of where tim (rx Motors) mounted mine.
