Pulley Belts
Started by Clarky, April 08, 2007, 01:21:51 PM
michaelb
Quote from: Jim_rx7What do you "block off" ?
when you remove air pump you just block off the pipes conected to the air pump - there is specilal stuff you can use but I forgot what is called - may be some one on here can remind me...
I can take a picture of my engene later and post it here if you like..
Regards,
Michaelb
Jim_rx7
Cheers mate, would be appreciated!
You could just use a biy of hose with a cork in the end could you not? lol. Crude, but it works.
Or some sort of rubber bung - seen them on peoples cars, but never anywhere to buy??!
RobbieRX-7
After answering a similar question on rx7club.com http://www.rx7club.com/showthread.php?p=6826925#post6826925, someone has mentioned that a 300mm belt is only about 10inches or so. I never even thought of this as i just took the information off robs site http://www.robrobinette.com/air_pump.htm, so i doubt it is a 300 mm belt, more like a 30" belt
 but thats just a guess. Im after a spare belt myself.
