mm what to buy
Started by mikeyh, September 14, 2006, 07:51:39 PM
mikeyh
got alittle cash now so looking for advice on what mods to buy first.
already has straight through exhaust and thats it.
was thinking of
induction kit
intercooler(which one not sure)
gauges(the ones i showed you in my last thread)
power fc commander
maybe not all of the above but at least i can get a cpl of things
any help and advice as tyo what to go for first is appriecated
mike
shaunwil
Go for the power fc first, then get the car tuned to your current setup. It can make a big difference !
Shaun
Jono FD3
FC & IC I\'d go for personaly!!!
Jono
mikeyh
if i was to add the ic later on would the pfc need to be re-mapped?
just tring to work out what order to buy them in asd not wanting to have to run up and down county all the time for mapping.
really close to buying pfc and cheapest so far has been 440
shaunwil
yes but the mapping session will only be a small one, the initial main mapping is usually about 300 quid, then if you stick an ic in it may only cost another 75 quid to have remapped.
Shaun
mikeyh
ouch didnt know a remap was that much
so in total im looking at about 1400 just for mods and remap.
mmm might keep saving and get it all done at once hopefully get a few secong hand parts.
cheers
mikeyh
with all that work any ideas to bhp?
Devil\'s Refugee
I have induction, full exhaust, Apexi and Greddy SMIC. Prob looking at 300bhp for this.
If you\'re buying an IC, get a V-Mount mate.
mikeyh
been offered a  blitz 3 row fmic is this any good?
Devil\'s Refugee
It\'s swings and roundabouts. I love the look of a FM, but for a Rex it restricts the airflow to the radiator, so you may see an increase in water temps.
V-mounts are supposed to be the best for airflow and keeping the rad nice and cool(ish!)
Would investigate more before buying tbh.
I bought a 3-row Greddy SMIC cheap from RHDJapan. They still have a couple in stock, it might be worth a look as a quick fix since they use existing mounts etc so not a lot of work involved to fit them. Will be buying a V-mount later when the bank balance has started to build itself up again ;)
kermit
With a straight through exhaust the first thing I would get on there is a PFC. The larger SMIC works well in the standard position.  If you fit Air filters make sure you make a heat shield and get a good bit of ducting to direct air flow to them.  With those mods you will probably hit the limit of your fuel system.
I know of a nice thick RE-Amemiya SMIC that should be for sale in a few weeks time if your interested.
