3 rota fd3
Started by craig, May 06, 2006, 08:14:11 PM
craig
hello long time since i have been on  hello to you all :D  just a quick question what has to be done to an fd3 to fit a cosmo engine  into it  if you already have the cosmo engine  cost as well and is it somthing a novice could do ???
thank you for any help   :cheers
kev-yorks
It\'s possible but to get it right your looking at a lot of £ and time Pip WGT is doing one at the moment. Your best place for info is rx7 owners club in the states.
Kevin
Regards Kevin
craig
hi ya kev long time no see,it was just a thought as i have blown my 13b up and did not realy want to recon it,thanks for the info ill have a bigger look
20B_boy
Budget about 10 times the cost of a 13B :)
R.
antnicuk
Quote from: 20B_boyBudget about 10 times the cost of a 13B :)
and 10 times as long to do!!!   :confused:  :confused:
normski
Quote from: antnicukand 10 times as long to do!!!   :confused:  :confused:
And How!  :Typing
DMRH
Quote from: craighello long time since i have been on  hello to you all :D  just a quick question what has to be done to an fd3 to fit a cosmo engine  into it  if you already have the cosmo engine  cost as well and is it somthing a novice could do ???
Certainly something a novice should not attempt. You have failed to specify if you want to install a 13B-REW or 20B-REW Cosmo engine. The former should be easier & the latter is what the guys above are groaning over.
A 20B swap is a big cost that sometimes is too much for an experienced rotary shop & they bodgey it up. Be aware
REgards
normski
#7
Well as far as I know it\'s a a nice Cosmo engine, or was till Pip got hold of it. Now it\'s a monster Cosmo. :god
Your right, but our Friend Pip is known as the master on these rotory engines he has been playing with them for around 30 years. His rep is Ext/ high :god
Bit slow at times but he does it right!
