Wayne's boosted 8 project
Started by Mr Spiller, March 14, 2020, 10:48:44 AM
Mr Spiller
Quote from: boosted on July 17, 2020, 03:27:34 PM
Grant will choose you suitable turbo from efr range..8374 maybe a tad too more than 420hp..more like 750hp full chat.
Sent from my SM-N950F using Tapatalk
Just got out my big boy turbo now
Sent from my iPhone using Tapatalk
Grant Monkhouse
GT 35R or what ever the latest version Garret are offering would probably be perfect.
Clive spec turbo would be exactly what your after too.
Different back housing and running. Lower boost at first be perfect.
Bridge ports will spool up turbos quicker.
You can run a smaller turbo but run a large turbine housing
Turbine housings aren't expensive either so you can just swap them when you want to alter your power band and power range
Sent from my VOG-L09 using Tapatalk
Grant Monkhouse
Garret G25-660 would be a great choice but they're not cheap at all
Mr Spiller
Quote from: Grant Monkhouse on July 17, 2020, 05:21:20 PM
Thanks Grant
I’ll look into them
Will take a while for it all to sink in and understand
Much appreciated
Did you see my reply  to that orange  RX7 ?
Grant Monkhouse
The new G series also come in reverse rotation options so they can fit better. They also don't bother offering divided entry on the turbine side with them because they are so responsive compared to what they used to be, especially with the billet wheels and ball bearing technology.
The 660 number is what HP they are capable of but when you apply that to our rotaries it means less.
My turbo is rated at 800hp on a piston engine but more like 600-650 on a 13B.
So the 660 probably equates to some where in the 400 range
HOWEVER
Because rotaries run hotter than piston engines we can use bigger turbos as we can spool them faster....
The GT35R used to be a great popular choice for 13Bs, fast spooling etc but they now offer that turbo in the G35-900 and G-1050 whereas before people chose them for 450 hp
Absolute minefield.
Pick your budget then look at different options
boston-rotary
Wayne i think i'm going with the borgwarner 8374 iwg AR 0.92 twinscroll T4  :icon_thumright:
Grant Monkhouse
What's the turbo you have now?
Mr Spiller
Quote from: Grant Monkhouse on July 17, 2020, 05:55:23 PM
Me or Boston rotary ?
boston-rotary
Quote from: Mr Spiller on July 17, 2020, 05:57:21 PM
Grant i'm at the same stage there abouts as Wayne still work in progress
Grant Monkhouse
You.
I'm just looking on turblown/turbosource site as they have loads of kits for rotaries, loads of dyno testing and comparisons
Mr Spiller
Quote from: Grant Monkhouse on July 17, 2020, 06:06:57 PM
You.
Feel a bit daft really as I don’t even know what’s I’m looking for
Leaving all the searching to you
Hers the one I currently have which would suit your car
Grant Monkhouse
Yep S475 be ideal for my car, especially with the methanol and no intercooler
Mr Spiller
Quote from: Grant Monkhouse on July 17, 2020, 06:17:59 PM
Can do a deal  , yours is right for mine if I remember ?
Grant Monkhouse
Iv cut a hole in my turbine housing
Mr Spiller
Quote from: Grant Monkhouse on July 17, 2020, 07:11:06 PM
Oh yeah ,..........,
They are cheap mind
