ABS testing
Started by Donato, September 22, 2004, 12:33:54 PM
Donato
Took the below passage from scuderiaciriani.com...
Make sure that the ABS memory error codes have been cleared from memory [connect TBS to GND in the diagnostic connector, turn ignition on (don\'t start engine), press the brake pedal 10 times at intervals of less than 1 second. If successful, the ABS warning light will come on for 3 seconds, then go out] Remove jumper wire and turn igntion off.
On my 92 3rd gen it doesn\'t have TBS in the diagnostic connector and my abs warning ligh is now permantly on. Anyone know if there is another connector i can connect to?
Donato
Donato
BUMP.
Anyone here help? My ABS light is on constantly and i have an MOT coming up soonish...
:D
