What month was MY RX7 made in ?
Started by Shaq, September 21, 2004, 04:49:17 PM
Shaq
Just trying to help someone out, how do you find out the month your JDM rx7 was made in ?
i found this info but still no help ??!?!
"JM1" "World Manufacturer Identifier" for Mazda
"FD" RX-7 series
"33" body style ("33" = coupe)
"1" "Misc ID field" (1993: "1" = US, "2" = Canada.)
(1994: "3" = manual seat belts, 2 airbags)
(1995: "3" = manual seat belts, 2 airbags)
"1" "Check Digit" (used to verify that a VIN is not bogus)
(calculated for each car)
"P" year model code (1993 = "P")
(1994 = "R")
(1995 = "S")
(Q was not used)
"0" assembly plant code ("0" = Hiroshima)
"200001" serial number (1993: started with 200001)
(1994: started with 300001)
(1995: started with 400001)
thanks
shaQ
scooby_si
thought 40.......were 16bit ECU\'d variety & i thought that was 96?http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/4/4_6_2v.gif\' border=0>
Si
Iwan
Post your VIN, I will check it out.
REgards
Iwan
still remember,
NO ROTOR, NO MOTOR !
