Rx8 231 eshafts
Started by Grant Monkhouse, July 23, 2021, 11:03:38 AM
Grant Monkhouse
Good used eshafts please, looking for 2/3
Have you thought of RX-8 shafts, much more readily available
Grant Monkhouse
That's what I'm looking for Clive, rx8 231 shafts. Think iv got ahold of a few
Sent from my VOG-L09 using Tapatalk
re japi
If you are using Renny e shaft, you beed to use HP Renny rearings and bearings too.
Low Power and High Power E shafts are the same, but gearing has big differense. LP versions are crap, but HP is basically the same as FD has
Lähetetty minun G8141 laitteesta Tapatalkilla
Use RX-8 231 Stationary gears with E04 Bearings as these take higher revs (dont use 192 gears)
The race car has had RX-8 shafts in for years because they are lighter.
