RS Power Projects 20B see's the light!
Started by leeroy_25, May 21, 2016, 08:38:04 PM
leeroy_25
Some of you will have been following my build on my website www.rspowerprojects.co.uk as sadly these days I barely have time to keep that up to date yet alone fill in a forum thread. I do pop in to say hi form time to time though and appreciate the info I get when needed. So I thought I would share a video of my project 20B that is not yet on my website! It saw daylight for the first time in a few years yesterday and made it's way to a dyno for a little bit of light setup while I decide to do with the engine.
I didn't really set out with the aim of big power as I wanted to limit boost to 10psi on the wastegate and run maybe 6500 rpm.
Sadly due to being sold a completely wrong spring somewhere down the line the wastegate was only making 4psi! After managing to fudge a bleed valve into the system we were able to get a bit of boot albeit spiking and then not holding very well. but manage to pull it up through the rev range to 6500rpm in the end but the boost dropped massively after around 5000rpm. So peak power was made just after that at 5600rpm and about 8psi boost. 412BHP which in reflection isn't half bad all things considered! So a bit bitter sweet. Main thing is everything seemed to work okay. Turbo maybe a bit more laggy than I would hope but a bit unfair to judge with the duff setup.
1st run up to around 4500rpm
4th run after some messing with the wastegate to try and achieve some boost!
leeroy_25
Please delete blank links above and replace with these if it works!
Thank you
1st Pull
https://youtu.be/PxxG1LR_ys4
Final Pull
https://youtu.be/oLuSgHEOxpo
re japi
Quite interesting looking project you got there! :) Keep up the good work...
Those wheels are nice, what are those?
And you have quite unusual intercooler setup. Any reason for that? :)
Real nice build that will have taken an enormous time and effort to get to this point  :wee_hee: :bravo_2:
leeroy_25
So I finally caved in and joined facebook. Mainly for car stuff. So as well as my website I now have a facebook page which you can find @rspowerprojects. I hope some of you will follow me and help motivate me through the final big push to get this thing on the road!
See you on the other side!
