no oil in oil catch tank?
Started by SCOOMER, August 18, 2004, 11:50:23 PM
SCOOMER
hi all, I fitted a oil catch tank about a year half ago and havnt had a single drop caught by it!?? Whats going on???
Ive had it cheaked out to see if its fitted correctly and its A ok.
Scott.
g11ary
would not worry too much, a twin will produce slightly less than a single, and it was not until I got on track at Spa that I ever saw any moisture appear, plus if you have had a small amount over that sort of period it may of evaporated. If it filled regular it might mean trouble.
Stop driving like a pussy and cane it more, especially on track where you have the centrfugile forces required. (hard cornering is the tick) LOL
20B_boy
Sounds like u have a healthy motor and turbos then. May be :)
They usually fill them if things are tired. Or as Gary says, when they are being caned a lot...
R.
SCOOMER
scooby_si
Or (paranoid mode on http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/4/4_11_4.gif\' border=0>) is it definately connected correctly? If so show us sum pix i will havw to install mine soon & could use some tips here....
Si
