Horn faulty
Started by Myrx8, September 25, 2015, 08:21:20 AM
Myrx8
Hi, I have a UK 2009 RX8, my has horn stopped working, I have checked fuses and relays all are ok, I think it is the solenoid as now the horn somtimes works, the problem is I cannot find the location of the solenoid, it will be helpful if anyone knows thr location of it
best regards
Richard
boosted
Had a quick look at s1 drawings on here mate and no solenoid. P61 and p62 in electrical section...horn fuse 15a and relay...id remove both check connections clean and report back.
Myrx8
Hi, thank you for your response, I have swapped like for like fuses and relays from the fuse box, no change, I have seen it on the internet that someone else had the same problem and they said it was the solenoid, I suppose they could be wrong, another thing that happens when the horn is not working is the indicator lights do not flash when opening and locking the doors, but as soon as the horn works they flash again, tomorow I will check if the alarm works when the horn is in fail mode
Best regards
Richard
Dragun
Can you hear the horn relay click when you press the button and it does not work?
[SIGPIC][/SIGPIC]
Rotary Massacre
   Dare To Be Different...
Myrx8
Hi, no I cant hear any solenoid or any kind of noise when the horn is not working, the horn has worked for the last few days, with the noise I do not think I would hear the solenoid anyway, then yesterday it stopped again, still trying to analyze if anything else is effected, thank you for your response and if you can think of anything else to check would be appriciated, I will update when I have somthing more
Best regards
Richard
