Coolent and air bubble help
Started by monkeyboy, August 04, 2004, 07:52:39 PM
monkeyboy
Got some kind of air lock in the coolent system, tried bleeding but got really really bad air what can i do?????
Iam in west yorkshire and need some where to take it any ideas???
Please
fly
I think WGT are in cheshire, thats not to far from you.
http://www.wgtautodevelopments.co.uk/
gsb876
Sorry if you have tried this:
Does the rad have a bleedin nut at the top? if so open up that nut then start car up, bubbles should start coming out of there.
Leave running for approx 10 mins, then screw nut back in fill with water/coolant and do the same procedure again just to be sure, if you have tried this and no joy then take to specialist, however avoid driving the rx as with a air pocket in there it will over heat pal.
Gurj
When filling, only fill via the cap on the engine.
Many times people put too much water in the system and have all sorts of problems.
It could be you just need to burp the system,
Please  look here for Cooling Troubleshooting Problems.
http://www.scuderiaciriani.com/rx7/how-to_cooling_system.html
Hope this helps
monkeyboy
Is it usual to have so much air traped????
monkeyboy
monkeyboy
OK iv done everything on the links to bleed, burp the system but iv still got loads of air in the system....
What could be wrong? Just so i can budget how many cans of beans i need to live off
20B_boy
QuoteOriginally posted by monkeyboy
What makes u say this exactly?
R.
iaint
If what you\'re seeing is continual bubbles coming up through the filler tube then unfortunately you\'re probaby not seeing trapped air but exhaust gasses seeping into the coolant... sign of water seal failure.
One side effect of this is the coolant gets heated up far more than it normally would and exacerbates the problem.
Iain
gsb876
Dude if you\'re really stuck i\'d recommend you dont keep starting the car up, get it to a rx7 specialist before you do more damage mate.
monkeyboy
So how much of a big job is the water seals then?
20B_boy
Well you start by stripping the motor down to nothing and go from there :(
R.
Brett
Its an engine out job I believe....?
Are you running on the origional engine or have you had a rebuild?
I\'m assuming you havent allowed it to overheat at any point?
Brap Brap Brap Brap
monkeyboy
When the light sounded i turned it off
Well looks like its a rebuild then!!! bugger
monkeyboy
Pip is going to pick the car up first week in september so looks like i will have to get a bus pass:( :( :( :(
Well iv just paid out for some 18" rays new tyres and a full respay and a carbon wing and some nice skirts so she still looks nice and i guess when she has been rebuilt i have a car that will last years....
Well as he will have engine out mite just if i can get some new bits in there
I love my bank manager i really do, just hope he/she loves me:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
