Oil catch tank
Started by Jot17, February 13, 2015, 01:57:39 PM
Jot17
Quote from: boosted on February 21, 2015, 07:43:39 AM
I think a bit of trial and error is required. If you suss it then you can help others in the future. Can you mount the oil catch tank up in the corner by the brake servo? I home made mine from a spun aluminium drinks flask 99p from lidls. Works a treat.
Hi boosted,
Yes their is abit of space near the brake servo, but will that be a bit far or will that be okay? I will get the dimension of the catch tank that I'm going to buy and see if it will go there, if not then I'll have to try another place or possible different tank.
Jot17
Also shall I leave the top nipple blocked? Or get a connect 2 to 1 so I can't connect both lines to one hole of the catch tank?
boosted
Servo great spot nice long line so oil may not make it to tank and flow back into sump...might as well leave blanked.
Jot17
Quote from: boosted on February 21, 2015, 03:05:52 PM
Thank you boosted, really appreciate the help. When I do get it fitted I will post it and tell you how it goes. Thank you
Jot
