RX-8 OBD Codes
Started by clive, December 12, 2014, 09:51:00 AM
RX-8 OBD  codes
DTC No. Condition MIL DC Monitor item* Memory function Page
P0030 Front HO2S heater control circuit problem ON 2 HO2S heater ´
(See DTC P0030 )
P0031 Front HO2S heater control circuit low ON 2 HO2S heater ´
(See DTC P0031 )
P0032 Front HO2S heater control circuit high ON 2 HO2S heater ´
(See DTC P0032 )
P0037 Rear HO2S heater control circuit low ON 2 HO2S heater ´
(See DTC P0037 )
P0038 Rear HO2S heater control circuit high ON 2 HO2S heater ´
(See DTC P0038 )
P0076 VDI solenoid valve control circuit low OFF 2 CCM ´ (See
DTC P0076 )
P0077 VDI solenoid valve control circuit high OFF 2 CCM ´ (See
DTC P0077 )
P0101 MAF sensor circuit range/performance problem ON 2 CCM ´
(See DTC P0101 )
P0102 MAF sensor circuit low input ON 1 CCM ´ (See DTC P0102 )
P0103 MAF sensor circuit high input ON 1 CCM ´ (See DTC P0103 )
P0107 BARO sensor circuit low input ON 1 CCM ´ (See DTC P0107 )
P0108 BARO sensor circuit high input ON 1 CCM ´ (See DTC P0108 )
P0111 IAT sensor circuit range/performance problem ON 2 CCM ´
(See DTC P0111 )
P0112 IAT sensor circuit low input ON 1 CCM ´ (See DTC P0112 )
P0113 IAT sensor circuit high input ON 1 CCM ´ (See DTC P0113 )
P0117 ECT sensor circuit low input ON 1 CCM ´ (See DTC P0117 )
P0118 ECT sensor circuit high input ON 1 CCM ´ (See DTC P0118 )
P0122 TP sensor No.1 circuit low input ON 1 CCM ´ (See DTC P0122)
P0123 TP sensor No.1 circuit high input ON 1 CCM ´ (See DTC
P0123 )
P0125 Insufficient coolant temperature for closed loop fuel control ON
2 CCM ´ (See DTC P0125 )
P0126 Insufficient coolant temperature for stable operation ON 2
Thermostat ´ (See DTC P0126, P0128 )
P0128 Coolant thermostat problem ON 2 Thermostat ´
P0130 Front HO2S circuit problem ON 2 HO2S ´ (See DTC P0130 )
P0131 Front HO2S circuit low voltage ON 2 HO2S ´ (See DTC P0131)
P0132 Front HO2S circuit high voltage ON 2 HO2S ´ (See DTC P0132)
P0133 Front HO2S circuit slow response ON 2 HO2S ´ (See DTC
P0133 )
P0138 Rear HO2S circuit high voltage ON 2 HO2S ´ (See DTC P0138)
P0139 Rear HO2S circuit slow response ON 2 HO2S ´ (See DTC P0139)
P0171 System too lean ON 2 Fuel system ´ (See DTC P0171 )
P0172 System too rich ON 2 Fuel system ´ (See DTC P0172 )
P0222 TP sensor No.2 circuit low input ON 1 CCM ´ (See DTC P0222)
P0223 TP sensor No.2 circuit high input ON 1 CCM ´ (See DTC
P0223 )
P0300 Random misfire detected Flash/ON 1 or 2 Misfire ´ (See DTC
P0300 )
P0301 Front rotor misfire detected Flash/ON 1 or 2 Misfire ´
(See DTC P0301, P0302 )
P0302 Rear rotor misfire detected Flash/ON 1 or 2 Misfire ´
P0327 KS circuit low input ON 1 CCM ´ (See DTC P0327 )
P0328 KS circuit high input ON 1 CCM ´ (See DTC P0328 )
P0335 Eccentric shaft position sensor circuit problem ON 1 CCM ´
(See DTC P0335 )
P0336 Eccentric shaft position sensor circuit range/performance problem
ON 1 CCM ´ (See DTC P0336 )
P0410 AIR system problem ON 2 AIR system ´ (See DTC P0410 )
P0420 Catalyst system efficiency below threshold ON 2 Catalyst ´
(See DTC P0420 )
P0441 EVAP system incorrect purge flow ON 2 EVAP system ´ (See
DTC P0441 )
P0442 EVAP system leak detected (small leak) ON 2 EVAP system ´
(See DTC P0442 )
P0443 Purge solenoid valve circuit problem ON 2 CCM ´ (See DTC
P0443 )
P0446 EVAP system vent control circuit problem ON 2 EVAP system ´
(See DTC P0446 )
P0455 EVAP system leak detected (large leak) ON 2 EVAP system ´
(See DTC P0455 )
P0456 EVAP system leak detected (very small leak) ON 2 EVAP system
´ (See DTC P0456 )
P0461 Fuel gauge sender unit circuit range/performance problem ON 2
CCM ´ (See DTC P0461 )
P0462 Fuel gauge sender unit circuit low input ON 2 CCM ´ (See
DTC P0462 )
P0463 Fuel gauge sender unit circuit high input ON 2 CCM ´ (See
DTC P0463 )
P0480 Cooling fan No.1 control circuit problem OFF 2 Other ´
(See DTC P0480 )
P0481 Cooling fan No.2 control circuit problem OFF 2 Other ´
(See DTC P0481 )
P0500 VSS circuit problem ON 2 CCM ´ (See DTC P0500 )
P0505 Idle air control system problem OFF ¾ ¾ ¾ (See DTC P0505 )
P0506 Idle air control system RPM lower than expected ON 2 CCM ´
(See DTC P0506 )
P0507 Idle air control system RPM higher than expected ON 2 CCM ´
(See DTC P0507 )
P0562 System voltage low (KAM) ON 1 CCM ´ (See DTC P0562 )
P0564 Cruise control switch input circuit problem OFF 1 Other ´
(See DTC P0564 )
P0571 Brake switch input circuit problem OFF 1 Other ´ (See DTC
P0571 )
P0601 PCM memory check sum error ON 1 CCM ´ (See DTC P0601 )
P0602 PCM programming error ON 1 CCM ´ (See DTC P0602 )
P0604 PCM random access memory error ON 1 CCM ´ (See DTC P0604 )
P0610 PCM vehicle options error ON 1 CCM ´ (See DTC P0610 )
P0638 Throttle actuator control circuit range/performance problem ON 1
CCM ´ (See DTC P0638 )
P0661 SSV solenoid valve control circuit low ON 2 CCM ´ (See DTC
P0661 )
P0662 SSV solenoid valve control circuit high ON 2 CCM ´ (See
DTC P0662 )
P0703 Brake switch No.1 input circuit problem ON 2 CCM ´ (See
DTC P0703 )
P0704 Clutch switch input circuit problem ON 2 CCM ´ (See DTC
P0704 )
P0850 Neutral switch input circuit problem ON 2 CCM ´ (See DTC
P0850 )
P1260 Immobilizer system problem OFF 1 Other ¾ (See DTC P1260 )
P1574 TP sensor output incongruent ON 1 CCM ´ (See DTC P1574 )
P1577 APP sensor output incongruent ON 1 CCM ´ (See DTC P1577 )
P1686 Metering oil pump control circuit low flow side problem ON 1
Other ´ (See DTC P1686 )
P1687 Metering oil pump control circuit high flow side problem ON 1
Other ´ (See DTC P1687 )
P1688 Metering oil pump control circuit initial check problem ON 1
Other ´ (See DTC P1688 )
P2004 APV stuck open ON 2 CCM ´ (See DTC P2004 )
P2006 APV motor control circuit IC problem ON 2 CCM ´ (See DTC
P2006 )
P2008 APV motor control circuit/open ON 2 CCM ´ (See DTC P2008 )
P2017 APV position sensor circuit problem ON 2 CCM ´ (See DTC
P2017 )
P2070 SSV stuck open ON 2 CCM ´ (See DTC P2070 )
P2096 Target A/F feedback system too lean ON 2 Fuel system ´
(See DTC P2096 )
P2097 Target A/F feedback system too rich ON 2 Fuel system ´
(See DTC P2097 )
P2101 Drive-by-wire relay control circuit problem ON 1 CCM ´
(See DTC P2101 )
P2106 Throttle actuator control system-forced limited power ON 1 CCM
´ (See DTC P2106 )
P2107 Throttle actuator control module processor error ON 1 CCM ´
(See DTC P2107 )
P2108 Throttle actuator control module performance error ON 1 CCM
´ (See DTC P2108 )
P2109 TP sensor minimum stop range/performance problem ON 1 CCM ´
(See DTC P2109 )
P2112 Throttle actuator control system range/performance problem ON 1
CCM ´ (See DTC P2112 )
P2119 Throttle actuator control throttle body range/performance problem
ON 2 CCM ´ (See DTC P2119 )
P2122 APP sensor No.1 circuit low input ON 1 CCM ´ (See DTC
P2122 )
P2123 APP sensor No.1 circuit high input ON 1 CCM ´ (See DTC
P2123 )
P2127 APP sensor No.2 circuit low input ON 1 CCM ´ (See DTC
P2127 )
P2128 APP sensor No.2 circuit high input ON 1 CCM ´ (See DTC
P2128 )
P2135 TP sensor No.1/No.2 voltage correlation problem ON 1 CCM ´
(See DTC P2135 )
P2136 TP sensor No.1/No.3 voltage correlation problem ON 1 CCM ´
(See DTC P2136 )
P2138 APP sensor No.1/No.2 voltage correlation problem ON 1 CCM ´
(See DTC P2138 )
P2195 Front HO2S signal stuck lean ON 2 HO2S ´ (See DTC P2195 )
P2196 Front HO2S signal stuck rich ON 2 HO2S ´ (See DTC P2196 )
P2257 AIR pump relay control circuit low ON 2 CCM ´ (See DTC
P2257 )
P2258 AIR pump relay control circuit high ON 2 CCM ´ (See DTC
P2258 )
P2259 AIR solenoid valve control circuit low ON 2 CCM ´ (See DTC
P2259 )
P2260 AIR solenoid valve control circuit high ON 2 CCM ´ (See
DTC P2260 )
P2270 Rear HO2S signal stuck lean ON 2 HO2S ´ (See DTC P2270 )
P2271 Rear HO2S signal stuck rich ON 2 HO2S ´ (See DTC P2271 )
P2401 EVAP system leak detection pump control circuit low ON 2 EVAP
system ´ (See DTC P2401 )
P2402 EVAP system leak detection pump control circuit high ON 2 EVAP
system ´ (See DTC P2402 )
P2404 EVAP system leak detection pump sense circuit range/performance
problem ON 2 EVAP system ´ (See DTC P2404 )
P2405 EVAP system leak detection pump sense circuit low ON 2 EVAP
system ´ (See DTC P2405 )
P2406 EVAP system leak detection pump sense circuit high ON 2 EVAP
system ´ (See DTC P2406 )
P2407 EVAP system leak detection pump sense circuit intermittent/erratic
problem ON 2 EVAP system ´ (See DTC P2407 )
P2502 Charging system voltage problem OFF 1 Other ´ (See DTC
P2502 )
P2503 Charging system voltage low OFF 1 Other ´ (See DTC P2503 )
P2504 Charging system voltage high OFF 1 Other ´ (See DTC P2504)
U0073 CAN system communication error (See DTC TABLE [MULTIPLEX
COMMUNICATION SYSTEM] )
U0101 Communication error to TCM
U0121 Communication error to ABS HU/CM
U0155 Communication error to instrument cluster
U0167 Communication error to keyless control module
exiled-viking
