1996 RX7 FD3s
Started by McC, August 28, 2014, 12:38:14 PM
McC
MOT 12 months
TAX 6 months
I have owned this car for the past 5 years, it was bought on a whim, and needless to say I should of done my homework on these things before I bought it. It turned out that a seal had gone in the engine block. So it has been an on going project over the years. It\'s only been on the road for less that 10 months in the time that I\'ve own it.
The engine was rebuilt in 2012-13 by a Ian Duncan (rotarhead on here I think), local guy that used to hill sprint with his FC for the past decade. Everything was put back together and put back in and running by The Garage in Motherwell. Obviously since the rebuild was done as a homer there is no warranty on the engine however i do have a slip of paper stating the pressure that Ian had tested it to once he had built it.
The car came with no history at all, so I\'ve kept everything that I\'ve bought and done to the car on file.
The car:
Full rebuild with OEM seals, gaskets and tips approx 5000 miles on it.
HSD adjustable coil overs 5000 miles on them
18" x 9" rear 18" x 8.5" front Volk racing alloys wrapped in yokohama\'s
Apexi ecu and controller (the only ECU for rotary\'s) running base map.
New brake pads all round
Oil pressure gauge
Oil temp gauge
I have a boost gauge and Water temp gauge but haven\'t plugged them in yet (see pics)
Uras monkey magic side skirts
Garage Foresight Front Bumper (it was the first one in the uk last year, don\'t know now)
Unknown rear bumper
Carbon fiber bonnet
HKS filters
Still got the CAT installed
Unknown exhaust
Twin oil coolers
De-spoilered
SFS radiator hoses
HEL braided brake and clutch lines
ACT 6 Puck Clutch
URAS carbon backed front side lights (one cracked)
There are many spares that will be going with the car. Including a lot of engine components, minus the seal set, tips and gaskets, possibly enough engine bits for a rebuild. (Pictures can be sent)
Good points:
Freshly re-sprayed
Alloys acid dipped
Engine, Clutch, brake pads, suspension only 5000miles
Bad points:
No warrenty on the engine nor compression tested
Rev counter is a bit tempermental, either works or it doesnt. (Apexi commander (ECU) gives a Rev display
Only drivers side Headlight pop up works (they can be manualy put up, hence how it passed an MOT)
One cracked front side light (i have replacements tho)
I\'m looking for £7,000 o.n.o
I\'m really looking for cash only, as I\'m getting my brothers car at the end of September, but I am open to offers. Preferably something diesel and german (i.e. reliable) if part exchanging, I can arrange delivery at buyer expense.
I have probably missed some things, so hit me with any questions.
The car is advertised elsewhere so I have the right to remove at anytime.
Thanks for looking
Here is a link to my eBay:
http://m.ebay.co.uk/itm/151394735820
boosted
Looks smart in white! GLWTS
McC
Bump!
Would like this gone before the 24th September
RotorHeid
Hi, didn\'t noticed it until today.
It was request to rebuild to mazda spec with all new mazda factory parts i.e
 sideseals/ wavy springs,
  two price apex seals/springs.
corner seals/springs
inner/outer oil control o rings /springs.
pilot bearing/seal and all hardware soft seals.
On the oil side of eccentric shaft was modify by plugged in by single grubscrew on a bleed hole to replaced the thermal pellet.
The ports was left standard.
The water jacket was pressure tested for 5-10 minutes at this time and was accepted passed.
It\'s good clean engine.
GLWTS
McC
Quote from: RotorHeid;882613Hi, didn\'t noticed it until today.
GLWTS
Cheers Ian!
