Oil Filter Relocation Options
Started by imebgo, August 19, 2014, 12:55:10 PM
imebgo
Hi, I have a need to move the oil filter because theres not enough room in the transmission tunnel for the whole assembly.
So, I want to move the whole pedastal part elsewhere in the car, so I thought about using a peice of aluminium with M12-AN10 fittings in it to basically relocate the oil filter ports on the engine, and move the oil filter assembly.
There is not enough room to keep the oil filter assembly, and just use a standard relocation kit to move the filter, I need to also move the part with the elbow off to the T/Stat / Oil cooler.
e.g:
Would the above work?
And are AN10 lines ok?
Thanks!
imebgo
Or, a simplification - as both passages on the rear plate go into the block
, 1 to feed the engine, and the other one to the regulator.
This enables me to use a generic oil filter mount.
Any thoughts?
Thanks!
