Twin plate help
Started by Palmeruk, February 08, 2014, 03:25:12 PM
Palmeruk
Hi ive put a hks twin plate in my fd, i used the standard release bearing and ring that holds the bearing to the pressure plate, now when my engine is running and i press the clutch pedal down it bounces back and makes a clunking noise, sounds like the fork is hitting the plate, any ideas why? :-(
TRIND-FD
Bearing torn of fork snapped.  Look through the lower inspection plate of the gearbox with a torch and get someone to press the clutch pedal. With the engine off. You should see what\'s going on.
V8 fd\'s rock :cool
Palmeruk
Ok thanks ill have a look, should i be using a different ring from standard to hold the release bearing to the plate?
colum
There should be a different release bearing and rod with the hks clutch, if you use oem the clutch won\'t operate properly
