Cutting out
Started by J4P RX, June 08, 2003, 11:45:38 AM
J4P RX
My car keeps cutting out when I stop.  It always starts ok, so I drive off.  When I next stop, the revs just kind of drop down and the engine cuts out.
Its done this a few times now, but starts ok again as long as I blip the throttle whilst trying to start it.
Any idea whats up.  It only seems to do this at night, and when cold.  Towards the end of my journey I have no problems.
Lee
Glenn Butcher
Hi Lee,
Has anything changed on the car recently? i.e. exhaust etc.?
When were the spark plugs last changed?
Thanks,
J4P RX
No nothing has changed, spark plugs are pretty new.  Dont know exactly but probably < 1000 miles on them.
It does seem a bit odd, and I cant work out what its doing.  Im just paranoid about it at the moment so keep my foot on throttle at idle to make sure it wont happen.
Lee
Nath
This has started happening to me , the last thing i had changed was the Power FC , and since this was fitted i have have the Cat heat light on all the time , but i have a decat????
any ideas?
fly
make sure the throttle cable isnt caught/stuck or the bolt that secures it to the plenum is in the right position.
Brett
Check the water and oil temp too.  Is it doing anything strange from cold?
 I know its a dirty thing to say but, If its cutting out when its hot it sounds a bit like poor compression, especially if your having to play with the loud pedal to get a restart.  How many miles has it done since new/rebuild?
 Also check your electric fans are working too, if the heat is spiking due to loss of the fans then any wear could start to show up...
Brap Brap Brap Brap
Brett
DOH!!!! Must read posts properly, its doing it when COLD!  I\'d check your idle controller then.  Sounds like the wax pellet may be sticking or summat!
Brap Brap Brap Brap
