Fuel pump issues, HELP please :)
Started by L18M, April 21, 2013, 03:47:28 PM
L18M
Ok thanks guys! will ground the plate (not obvious the plate is a ground, thought was just a cover for safety) and have another look, maybe take apart the wiring the previous person did to make sure is soldered properly and insulated.
top bombings :)
Quote from: L18M;866443Ok thanks guys! will ground the plate (not obvious the plate is a ground, thought was just a cover for safety) and have another look, maybe take apart the wiring the previous person did to make sure is soldered properly and insulated.
top bombings :)
The plate is the one that\'s oval shaped on top of the fuel tank, not the rectangular ally one that\'s in the boot which the wiring passes through ;-)
L18M
Quote from: Prof;866447The plate is the one that\'s oval shaped on top of the fuel tank, not the rectangular ally one that\'s in the boot which the wiring passes through ;-)
i knew that.. :2Confused
:Giggle:wiggle:Thumbsup! Thanks!
Quote from: L18M;866552i knew that.. :2Confused
Just making sure ;-)
How\'s it going - did you figure out if the pump is dead ?
L18M
will investigate tomorrow, weather permitting :)
L18M
woo hoo!! gotr it sorted now. turned out to be a dodgy ground on the white plug that sits on the fuel tank.
Fuel sender also works too now. Started up 1st time :)
just smokey due to oil in the exhaust (i hope its just that).
Anyone know the best way to clean excessive oil in the exhaust without taking the whole exhaust off?
Quote from: L18M;866642Anyone know the best way to clean excessive oil in the exhaust without taking the whole exhaust off?
Take it for a nice long spin :yes:burnout
Glad you got it sorted Liam :-)
TiddlesRX7
Good news mate. Glad she is up and running again. Not sure about cleaning the exhaust. I think a nice drive out could be the best answer.
Ade
L18M
Thanks guys :)
cant drive on the road. no mot :(  and the amount of smoke is horrendous!
vid link
https://www.youtube.com/watch?v=1MCf7r_oujM&feature=youtube_gdata_player
If you can park it so you can leave it running for say half an hour the exhaust should get hot enough to start burning the oil out, the odd rev is going to help as well.
L18M
thanks clive :)
lucky its windy where im parked so wont be too concentrated smokey smokey. Just pref not to smoke out the estate if possible but maybe no choice :)
