This is what happen to my engine(read please)
Started by Aliakeel, August 18, 2013, 09:00:36 PM
Aliakeel
Clive do me a fav and delete the thread please mate...it\'s really getting my nerve ..
boosted
Reading all of this bud it all points to broken cable/short on the fuelling side of things....If it was ignition then your eyes would be stinging and smoking.....
You prob had a partially broken cable and overtime it got worse...prob caused your first engine problems....
Id say map and engine fine.....broken cable or short in the loom on the fuelling side....as the engines been pulled the loom would have been fatigue even more.
These car are now old and the looms have been subjected to a lot of heat over the years. this will make the insulation and wiring brittle.
You\'ve paid for a map and rebuild...now unfortunately you need to pay someone to fault find.
keep the faith the FD is high maintenance mistress!
Brett
Has anyone checked the shielding & earth on the ignition side of things?
Brap Brap Brap Brap
