Timmys FD3S
Started by Timmyc, August 16, 2013, 09:41:27 AM
Timmyc
Another update:
Fitted all the wiring loom
Trial fitted the maaaaassive intercooler and rad setup but looks like I wont be able to use it due to keeping the a/c and twin oil coolers but will be able to when I get bored of the twin turbos and put on the backup to4r and ditch the a/c etc
Built up more of the engine bay, fitted p/s, a/c, abs, brake servo, brakes pipes, clutch master cylinder, braided clutch line etc etc
Cleaned up the fuel tank and fitted an in tank bosch 044
Bolted rollcage into final position using strengthening plates and refitted rear seats and paneling cut to suit
Rear bumper back from paint and fitted
Fitted a carbon rear diffuser and rear exhaust section
Re amemiya light cover back from paint and fitted
Tailgate back and fitted, glass in but ideally need a better condition one and a seal
Got the doors back and lambo hinges to see what they are like but waiting till nearer completion to fit the doors
Made 1 good set of twins out of 2 knackered sets, lined my lim with heat protective material and did the same on the o/s chassis leg and around strut tower and brake servo, went a little higher and further back than needed for the sake of the single turbo later
Used my greddy front mount I had and turned it into an in engine bay intercooler, made alloy brackets to fit it, trial fitted so c west style carbon lights as well
Tonight I have replaced all the fuel line and brake fluid to clutch master cylinder feed, all vaccuum pipes, double checked the wiring and solenoids, need to make some blanking plates for air pump removal gubbins, intercooler pipework, some coolant to throttle body pipes then should bd about ready to try fire her up :-)
fil_auto
Coming along very nicely, loving the rear end :)
Kitsan
Really looking forward to seeing this finished TimmyC, are you stripping the inside or keeping it stock? Any thoughts of a cage?
Timmyc
Thanks Phil :-) hopefully the whole thing should look pretty cool
All standard inside Kitsan apart from colour coded dash panels, door trim and a cusco dash dodger cage, rear seats refitted with cutouts for cage
