Rear Fog Light not working
Started by grinder, August 08, 2013, 06:41:38 PM
grinder
Thought I would ask here to see if anyone knows the quick answer
The car failed its MOT ( as per other thread )
But it also failed on the fog light not working
Now being a UK car , its fitted as standard , so does anyone know why its not working ??
The switch does nothing , bulb looks OK and there are no lights on the dash saying that its on or off
Is there a separate fuse for this ??
also I have lost all my dash lights aswell , could this be connected ??
Stu
The tightest man on earth
:Giggle
grinder
OK , cant find a fuse for it - but put a 15a fuse in where it says "FOG" , still no worky
Im wonder if we have damaged the wires when welding etc.. , or I can caught one when putting the trim back in
Took the centre console apart , and I have found a 12v feed when the lights are on
I think this is the switch for the front fogs , that I just put the fuse in
SOOOOOOOO , plan now is to jump the 12v from that into the rear fogs :)
I tried to get a voltage from the correct fog light switch and the best I get is 0.06v , so im wondering if that\'s just feeback from somewhere in the wiring
I don\'t like this "fix" but if it gets it thru a MOT ( when welded ) then im all for it
Still doesn\'t explain why nothing lights up on the dash though .. my clock dims when I put the lights on , so it KNOWS the lights are one , just no dimmer working on the dash
I checked the fuses and there is nothing blown .. I just hope its not the switch
:Giggle
