1989 rx7 fc turbo 2 for sale 80k miles £1200
Started by billybobbooth, August 02, 2014, 04:28:24 PM
billybobbooth
Decided as we have too many cars 5 with new car on way need to down size numbers. My insurance has changed so no longer can insure all my cars so selling the rx7 project car :( sad times.
The has now been sat for a year at our house slowly acquiring parts.
Over the winter I had all the drives side sill cut removed any rust and welded plate put in I have used 2.5mm plate so much thicker and stronger than the normal tin plate used this was all heated bent and welded.
The car runs perfect and is run up every month while been sat.
With new rear disc and pads and a pass side tail light and 2 mirrors although I do have usa mazda aero mirrors modified to work for right hand drive. shouldnt have a problem being moted.
I have a full set of replacement wishbones front and back rear and drive shafts. I have replacement rear subframe with good bushes.
I have a full bush kit for the car + arb droplink covers.
There is a set of tien hr coilovers that were sent off and new seals put in. These do need the adjuster ring buying these are £12 + vat each need 3 per shock as there spring rate adjustable with separate hight adjusted
The car has a bolt in 4 point cage bolted but never got round to welding in
Has the rear seats removed with bins and carpet inported from usa along with 2 mazda aero mirrors modified to work for right hand drive.
The car has a tiny bit of rust on sunroof. Sunroof is fully working last time I tried to use it.
It has faded red paintwork but that never bothered me.
Has full turbo 2 body kit as standard bit front lip is broken in middle. Wings are very solid and rust free have seen some with loads of rust. When did welding over winter there was no other rust I noticed.
Has new tyres all round on stock clean alloys
Has uprated rad with electric converted fans. Air pump removed. Perfect working turbo (happy to say this ill even show anyone who come to see the car and questions it)
Has turbo back 3 inch single system + 3 inch turbo - cat  then split 2.5 inch twin system
Electronic boost controler
Good stage 1 clutch in boot
There is loads more so much to list ill add pics later
Im after £1200 for everything on or for the car it will need to be trailered but if you bring rear disc and pads 2 mirrors and pass side rear light can be driven away on trade plates without a problem.
Please email or text or ring for more info or to come look
Its nice are with lots of bits and good running engine im not going to give it away for less than 1200 I have all the time in the world to sell this car.
Email billybobbooth@hotmail.com
Text ring 07475142082
billybobbooth
Forgot to add the suspension and shocks on car are all perfect bought replacements so could put bush kit on and just swap over and still have good replacement parts.
billybobbooth
http://www.ebay.co.uk/itm/331279272161?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Link to car on ebay.
Im after a semi quick sale I dont want to brake it or split the bits up as dont want to be left with a semi stripped shell. Its worth someones time to stip and sell.
But not selling compleate for less than 1200 if have to car will go as is stripped and every extra will be sold to make diffrance just a lot of listing would rather someone had chance to have some fun with it.
Sam.
If you resort to breaking it. Give me a PM i would be willing to take quite a few parts.
billybobbooth
The car wont be broken only the extras sold off then the car compleate at a lower price once the extras are sold off as in total want 1200 for the lot. Just better if was in one go rather than me having to list all bits separately taking up more time.
billybobbooth
Just fround paper wwork had new engine fitted 30k miles ago
