Going Single. What to get rid of ?
Started by AndyGen3, November 15, 2012, 11:18:35 PM
AndyGen3
Started stripping the engine bay of all non essential stuff to go with a single turbo.. did a search but nothing comprehensive came up on what pipes etc need to go and how to plumb for one turbo etc.
Anybody have any links ?
cheers
AndyGen3
Palmeruk
Am also looking for this but come across nothing as if yet
Hi Andy,
First question will be what Turbo set up are you looking at as this will dictate the fueling for the car and obviously you will need an Apexi ECU or similar to tune it .
If you buy a Turbo kit that\'s been on a car make sure it has the oil feed and return with it.
As for plumbing, its surprising how much is junked especially with all the rats nest gone with all its associated pipes,
The picture below shows one way of plumbing a single Turbo
If you carry this out yourself once the twins are off and the rats nest is gone it then starts to become simple to see how to fit and set up your new single turbo set up.
hope this helps
