Semi Weld in/Bolt in Cage FD3s
Started by rx7boy, August 28, 2013, 06:09:01 PM
rx7boy
I have for sale a semi bolt in roll cage for an FD, its a suburb fitting cage designed by Matt @ MPH Customs with one of the leading cage fabricators, this is brand new never fitted. Powder Coated in black. I planned on fitting it to my drift car but the project has been scrapped for the time being.
Couple of the key features.
  • Semi Bolt in (weld in base plates)
  • Non dash dodger to increase strength
  • Supurb fitting (tight against roof and front head bar)
  • Powder coated black
  • Helmet friendly due to fit
  • Weld in mounting brackets form added strength
  • Low single Door Bar for side impact protection
  • Removable front section for on road use.
  • BDC/EDC Spec
This is semi bolt in due to the mounting plates being welded in, this is done to ensure the cage fits as tightly as possible to the shell of the car.
The main benefit of this cage is how well it fits in the car, Matt spent a huge amount of time with the fabricators getting it sit in the car right and develop on from the existing cages available. No more bending your leg round the door bars to get to the throttle which happens on most other bolt in\'s. As you can see from the second to last photo the mounting plate is on the main sill, avoiding this issue.
The photo\'s below are of the same cage fitted to Mark\'s old drift car, my cage is the same just powder coated black instead of orange.
Any question please let me know,
Price is £700 collected from Aylesbury, I can arrange delivery of this on a pallet, I will need to get a quote based on your location.
DM-Motorsport.co.uk
