It\'s alive but not running right!
Started by Spence, May 16, 2013, 05:51:29 PM
Spence
So I got the fc started today, however idle is rough and tries to stall. We had to put separate wires to the coils to get power to them so not sure what\'s up with that.
Done a compression test and front rotor is just under 90 psi and rear is 75 psi. Not great but I don\'t think it\'s that bad.
My question is why does it idle so bad ad seems to have low down miss fire then as you build revs it clears?
Spence
Also I heard there is a way to get slightly better psi from rotors if you chuck something in there? Probably hasn\'t been on the road for 10 years.
Grant Monkhouse
Your seals may be stuck slightly with it being sat a long time. Have you put new plugs in? If you keep it running and squirt a bit 2stroke oil in the engine it should help free up the seals. It will smoke a fair bit until the oils has burnt off.
grinder
you can use a ATF trick if they are stuck ( auto trans fluid )
You can inject 5mm into each spark plug , leave it ( maybe overnight ) , the i think you have to start it .. it WILL produce clouds of smoke though
The ATF breaks down any carbon build up in the housings etc...
The tightest man on earth
:Giggle
Spence
Spence
Quote from: grinder;857902you can use a ATF trick if they are stuck ( auto trans fluid )
Won\'t there be 1 tip left untouched if you put it in the spark holes? Or put it in then turn it over?
Grant Monkhouse
Yes, crank the engine over by hand
Spence
Quote from: Grant Monkhouse;857920Yes, crank the engine over by hand
Thought so cheers.
Spence
Also does anyone think the compressions are ok?
grinder
nearly 1 bar between them .. its not ideal i dont think
BUT , it depends on what each face is like ( you should in real terms get 6 figures )
:Giggle
Brett
Are those readings conistent, or is fluctuating on each rotor?
Brap Brap Brap Brap
Spence
It\'s a normal compression tester so not one that tests each face.
the hat
Run the engine up nice and hot then a little water down the inlet ??? That\'s how we used too get all the crap out of the big old v8 twin turbo diesels offshore
