Rx8 Aux?
Started by GoldenMerc, January 24, 2013, 10:32:27 AM
GoldenMerc
Hi,
So I have a 2004 231psi Rx8, What i was wondering is would I need a new head unit for a aux cable, If so what do most members recommend ?
Ross
As the indicator assembly and heater controls are incorperated in the head unit, probably your ony way forward would be a custom unit
GoldenMerc
( I know it says you have to check firmware) http://www.therpmstore.com/store/p/133-XCarLink-USB-MP3-Player-Integration-Kit-for-Mazda.html
Have you had any experiences with this?
Will66
If your firmware is the early one then these are fine, I\'ve had a similar one on mine for 5 years.  It\'s good.
"Eat it with a chopstick!"
GoldenMerc
Do people replace the head unit normally then? or just do the aux switch thing?
Ross
Will66
Replacing the head unit is a pain on UK cars because of the climate control being on a common loom and panel.  You can get a double din for it but it\'s expensive.
Arnie_O
What sort of Audio are you looking to add via an Aux port?
Turbocharged 192ps RX-8 running Meth Injection on an Adaptronic
Fully Bridgeported 231ps RX-8 stripped for the Track
2nd Gen RX-7 TurboII on a GT35r (show winner)
exiled-viking
it can be done but its very costly and you can lose some of the 8s systems i thought about it due to being given two double din units but the air con is an issue so have dropped the idea due the fix costing around £500 to £600 :eek:
