Cataclean from mazdarotary parts
Started by nadz, January 15, 2013, 11:06:04 PM
nadz
Hi I wanted to know if anyone has used the cataclysm bottle from MRP and has it done any good or can it harm the car. Please advice.
http://www.mazdarotaryparts.com/b-catacleanb-1218-p.asp
I am looking to get a bottle but afraid it may harm if no one has used it.
Will66
Doesn\'t do any harm on RX8s.  So I can\'t see any harm on RX7s.
"Eat it with a chopstick!"
Mazdarotaryparts
Quote from: nadz;847727I am looking to get a bottle but afraid it may harm if no one has used it.
We have sold literally hundreds of bottles of this over the years and it defiantly won\'t do any harm as the RX-8 and RX-7 essentially share the same engine just with the modified intake and exhaust parts of the engine changed.
Personally used in in our RX-7\'s, RX-4, RX-8 plus normal road cars
To quote one owner who said he had honors degrees in engineering and chemistry in his signature,
 "always thought this type of product was snake oil but cataclean actually works"
A by product of Cataclean is, because it makes the combustion charge burn hotter to clean the cat out it should help clean carbon out of your engine and seeing as carbon gums things up inside Rotarys, this can only be a good thing for any Rotary.
Hope this helps.
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
nadz
ok sounds good so i have ordered it now. am i to put the full bottle in to the petrol tank and with how much fuel in the tank.
Will66
Run your fuel to about 1/4 of a tank, put the cataclean in, go for a decent drive (as much as you can on 1/4 of a tank of fuel in a rotary :) but plenty of revs and throttle) until you\'ve used most of the fuel in your tank then fill up.
nadz
ok thanks for that. if i receive it by the end of this week then i will be able to. other wise will have to wait till next week. as im using a full tank on a weekly basis.
